vcProperty
Property object with its own set of properties, methods and event handlers.
Children: vcBoolEnumProperty, vcBoolListProperty, vcBoolProperty, vcButtonProperty, vcExpressionProperty, vcIntEnumProperty, ... (see more)
vcBoolEnumProperty
vcBoolListProperty
vcBoolProperty
vcButtonProperty
vcIntEnumProperty
vcIntLimitProperty
vcIntListProperty
vcIntProperty
vcIntStepProperty
vcListReferenceProperty
vcMaterialProperty
vcMatrixEnumProperty
vcMatrixListProperty
vcMatrixProperty
vcMatrixStepProperty
vcProxyProperty
vcRealEnumProperty
vcRealLimitProperty
vcRealListProperty
vcRealProperty
vcRealStepProperty
vcReferenceProperty
vcStringEnumProperty
vcStringListProperty
vcStringProperty
vcStringStepProperty
vcUriProperty
vcVectorEnumProperty
vcVectorListProperty
vcVectorProperty
vcVectorStepProperty
Referenced by: vcGetPropertyStatement.SelectedProperty, vcProductTypeFilter.AcceptedFlowGroupsProperty, vcProductTypeFilter.AcceptedProductTypesProperty, vcPropertyConditionStatement.SelectedProperty, ... (see more)
vcPropertyContainer.create()
vcProxyProperty.TargetProperty
vcStatisticsSeries.Property
| Group | Integer | RW | Gets or sets the group assignment of property.See moreProperties are ordered by groups, and a group number is automatically assigned at the time of creation. This order can be overridden to have properties come before or after one another when listed in the GUI. |
| IsPersistent | Boolean | RW | Gets or sets if property value is saved with component or layout. Exceptions: ValueError: When changing the persistency of a built-in property. |
| IsVisible | Boolean | RW | Gets or sets if the property is visible in the Properties panel. |
| Name | String | RW | Gets or sets the name of property.See moreExceptions: ValueError: When changing the name of a built-in property. ValueError: When name is not unique inside the property container. |
| RebuildOnChange | Boolean | RW | Gets or sets if component geometry is rebuilt when the property value is changed.See moreExceptions: ValueError: When changing the component rebuild behavior of a built-in property. |
| ReconfigureOnChange | Boolean | RW | Gets or sets if component structure is reconfigured when the property value is changed.See moreExceptions: ValueError: When changing the component reconfiguration behavior of a built-in property. |
| UpdateOnChange | Boolean | RW | Gets or sets if simulation world is updated when the property value is changed.See moreExceptions: ValueError: When changing the simulation world update behavior of a built-in property. |
| WritableWhenConnected | Boolean | RW | Gets or sets if property value can be set when component of property is connected to another component via interface. Exceptions: ValueError: When changing the writability of a built-in property. |
| WritableWhenDisconnected | Boolean | RW | Gets or sets if property value can be set when component of property is not connected to another component via interface. Exceptions: ValueError: When changing the writability of a built-in property. |
| WritableWhenSimulating | Boolean | RW | Gets or sets if property value can be set when a simulation is running. Exceptions: ValueError: When changing the writability of a built-in property. |
| delete | None | None | Deletes the property.See moreExceptions: ValueError: When deleting a built-in property. ValueError: When the property container cannot be modified. |
| OnChanged | vcProperty property | Triggered when value of property is changed. Parameters: property (vcProperty): The property that changed. |
Example: Create New Property
"""This example shows how to create a property and set its value.""" import vcCore as vc comp = vc.getComponent() prop_container = comp.Properties counter_prop = prop_container.create(vc.vcPropertyType.INT,"Counter") counter_prop.Value = 10
Example: Wait for Property Value
""" This example shows how to wait for a property value to change.""" import vcCore as vc comp = vc.getComponent() async def OnRun(): int_prop = comp.Properties["Integer_1"] await int_prop.waitFor(5, waitTrigger = True)
Example: Read Property Value
""" This example shows how to read a property value from a component.""" import vcCore as vc comp = vc.getComponent() counter_prop = comp.Properties["Counter"] print (counter_prop.Value)
Example: Wait for Property Value Filter Function
""" This example shows how to wait for a property value to change if the value passes the filter function.""" import vcCore as vc comp = vc.getComponent() async def OnRun(): int_prop = comp.Properties["Integer_1"] # use the inline lambda function as filter await int_prop.OnChanged.wait(lambda x: x.Value > 5)
Example: Delete Property
"""Deletes a component property.""" import vcCore as vc comp = vc.getComponent() counter_prop = comp.Properties["Counter"] counter_prop.delete()
